Введение
Replacing the Valve cover gasket can be a very easy process. If you need any help finding the right part, here is the part number: 12040-PCX-305. You can purchase the gasket on Honda parts Now. There isn’t any injuries you could get from doing this job but I would suggest wearing gloves to not have oil residue on your skin. Don’t lose any parts or screws and store them in a secure place.
Инструменты
Запчасти
Using the 3/8" drive ratchet, remove the four screws that hold on the spark plug cover.
Unplug both plugs on the back of the valve cover.
Undo the clip holding the wire harness.
Using the 10mm deep socket and the Torque wrench, remove the four 10mm bolts from all four coil packs.
Only unplug the last coil pack. Then, pull all the coil packs out of the sparkplug holes.
Loosen clamps on both vacuum lines. Slide both lines off. Remove the oil dipstick and oil cap.
Use both hands and pull up on valve cover slowly.
Clean oil residue off the surface where the valve cover sits.
Compare your old and new parts and make sure they are the same. Clean the inside of the valve cover with an old rag.
Apply a small amount of force on both sides of the cover. Gently wiggle it on and check to see if nothing gets caught on it.
Put both vacuum lines back on and tighten them down with the clamps.
Put on the new washers that hold down the cover; these easily pop on.
Place the all 4 coils back into the sparkplug holes and tighten the bolts. Plug in the last coil pack.
Tighten the five bolts that hold down the valve cover.
Tighten down your sparkplug cover with the 4 bolts.
Reattach the oil cap and oil dipstick back on.
