2006-2013 Toyota Corolla Ignition Coil Replacement
Выберете то, что вам нужно
  1. 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: шаг 1, изображение 1 из 3 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: шаг 1, изображение 2 из 3 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: шаг 1, изображение 3 из 3
    • Pop the hood and remove the black plastic cover over the engine.
    • There is nothing to unscrew, or unlatch, and the cover should lift off. Once removed, the top of the engine will look like the third picture
  2. 2006-2013 Toyota Corolla Ignition Coil Replacement: шаг 2, изображение 1 из 2 2006-2013 Toyota Corolla Ignition Coil Replacement: шаг 2, изображение 2 из 2
    • Unplug the ignition coil you wish to replace. The coils are numbered one though four, left to right.
    • Do not unscrew the bolt on the ignition coil before this step. It makes the electrical plug more difficult to remove
  3. 2006-2013 Toyota Corolla Ignition Coil Replacement: шаг 3, изображение 1 из 1
    • Unscrew the bolt of the coil that needs to be replaced.
    • Be sure to put the bolt in a place you will not lose it!
  4. 2006-2013 Toyota Corolla Ignition Coil Replacement: шаг 4, изображение 1 из 2 2006-2013 Toyota Corolla Ignition Coil Replacement: шаг 4, изображение 2 из 2
    • Pull the coil straight up and out. It should come off of the spark plug with little resistance.
  5. 2006-2013 Toyota Corolla Ignition Coil Replacement: шаг 5, изображение 1 из 2 2006-2013 Toyota Corolla Ignition Coil Replacement: шаг 5, изображение 2 из 2
    • Apply a pea-sized amount of grease to the new ignition coil. It should be all around the rubber tip around the bottom.
    • While not required, this step will make any future replacements much easier.
  6. 2006-2013 Toyota Corolla Ignition Coil Replacement: шаг 6, изображение 1 из 1
    • When inserting the new ignition coil, press down lightly to ensure it is completely in place.
    • Re-plugging in the ignition coil, and re-screw it in. This can be preformed in either order.
    • Repeat steps three through five as necessary for the other three ignition coils.
Заключение
Еще один человек закончил это руководство.
Henderson Gillette
Участник с: 09/23/23
160 Репутация
1 руководство автора
Команда
Austin Community College, Team 22-3, Watkins Fall 2023 Участник Austin Community College, Team 22-3, Watkins Fall 2023
AUSTINCC-WATKINS-F23S22G3
2 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 76
За последние 30 дней: 304
За всё время: 1,068
