Введение
In this guide, we will replace the battery of a 2006-2011 Honda Civic key FOB. This is a fairly simple project that can be completed rather than potentially spending a minimum of $90 on a replacement.
Выберете то, что вам нужно
Using the Phillips #0 screwdriver, remove the single screw from the bottom of the key FOB.
Remove the inner shell from the outer shell by pushing the buttons to loosen the inner shell.
To reassemble your key FOB, follow these instructions in reverse order.
3 участников успешно повторили данное руководство.
