Введение
A broken PCV breather hose can cause several problems, such as a poor fuel economy, engine misfire, or a check engine light (see YourMechanic.com). Engine tubes and hoses may become brittle and crack, snap, and leak; such damage must be repaired promptly and correctly. With this short and easy guide, you can save time and money by quickly replacing your broken breather hose in your 2006 Audi A4 2.0T Quattro (B6).
Be sure to turn off your car and engage the parking brake.
Выберете то, что вам нужно
Lift the hood and remove the engine cover by pulling it up with two hands.
Locate the breather hose attached to the intake manifold.
Look for the grooves on each end of the hose.
To detach the hose, squeeze on the grooves found in Step 2. Use pliers if needed.
At the same time, pull the same end of the hose away from its connection to the engine (the valve).
Repeat this step to remove the other side of the hose.
