Введение
This guide will show you how to remove the door handle, the main and two upper panels, the bottom latch, and the cable itself in a simple and safe way. This fix should take about 10 steps.
Выберете то, что вам нужно
Remove the plastic cover from the door handle using a 7.6 cm slotted screwdriver.
Insert the screwdriver into the small opening found at the top of the plastic cover.
Carefully tilt the screwdriver upward to remove the plastic cover.
Remove the two 6 mm hex screws using a 6mm socket.
Turn the screwdriver counter-clockwise to loosen and remove the screws.
Grab the door handle and remove it from its location.
Remove the other plastic cover by pulling outward to snap it out of its location.
Remove the three 6 mm hex screws off the main door cover using a 6 mm socket. There are two screws at the top and one at the bottom.
Gently, but with a strong force, lift the door cover about an inch or two high. Then, carefully pull it outward.
Snap out the upper end of the cable out of its location.
Using a plier, lift the cable high enough so that the little ball can come out through the round opening above it.
Remove the three T27 hex star screws using a tamper torx screw driver. The screws are found at the bottom of the door.
2 участников успешно повторили данное руководство.
