Введение
This guide will show you how to replace the side view mirror of a 2006 Toyota Highlander, though it will also work for 2000- 2007 models as well as any hybrid variants. Because of the way the mirror is connected to the car, this guide will show you how to take off the entire door panel in addition to the steps involving the mirror itself.
Выберете то, что вам нужно
Pop out the master switch panel with a heavy duty spudger by sliding it in from the side.
Flip the master switch over to see the plug.
Unplug the master switch panel by firmly pushing down the notch and pulling it out.
Remove the door handle with the spudger by sliding it in from the side. Make sure to get it into the middle as there is a notch there holding it in place.
In the door handle area, pry the small screw cover open with a spudger.
Remove the single screw with a Phillips screwdriver.
Use a Phillips screwdriver (or any other sufficiently thin object) to push in the center piece. Use a spudger to remove the push cap.
Completely remove the door panel by feeling for a gap underneath the door. Use the heavy duty spudger to pop the door panel off.
Take the door panel and lift it up and over to completely remove it from the door.
Check for plastic pins. If some are stuck do the door, use a clip to pull it out. Slide it back into the door panel for later.
Slowly pull the mirror out (make sure the connected wire also comes out).
Place in the new mirror by doing the above bullet point in reverse.
To reassemble your device, follow these instructions in reverse order. The reminder bullet points will notify you if any special actions are required for reassembly.
