Введение
This guide will show you how to replace the map lights of your sixth generation Nissan Sentra (years 2007-2012). Since each car has its own unique features, and while there are guides to fix others, this guide allows Nissan Sentra car owners to replace their car map lights without the risk of damaging the car parts or their vehicle.
When performing this guide ensure that you are in a very well lit area to aid with visibility. Before you begin, make sure the car is off and in park.
If you suspect that your map lights are out, turn them on and off a few times prior to the replacement, however, if you turned your map lights on to test them prior to beginning this guide, wait a few minutes before following the steps presented before you. This ensures that the bulb is cold, which prevents any burns or injuries.
Выберете то, что вам нужно
Use a spudger or opening tool to gently pry the lens out. Begin in the small space between the lens and console.
Using the Phillips #2 screwdriver, remove the 19.1 mm screw in the middle of the console.
Pry the console out gently from the ceiling of the vehicle by pulling it towards you.
Rotate the bulb clip counterclockwise until it's loose to remove it from the console.
Put the bulb clip back into console and turn it clockwise to secure it in place.
Once you have repeated the same steps for the other bulb, gently place console back into its spot in the vehicle by pushing it in.
Make sure to test that the lights are working.
Once you have done that, put the 19.1 mm screw back in place with the Phillips #2 screwdriver.
If all goes well, your car now has new bright map lights and you will now have the knowledge to perform future map light replacements for your 2012 Nissan Sentra. If this knowledge is forgotten, our guide will help provide you with proper instructions and indications on how to replace your map lights again. If you know of anyone with this model of car, and they need a replacement of their map lights, send this guide their way in order to assist them in the process of replacing their map lights. Like iFixit says, "if you can't fix it, you don't own it."
Еще один человек закончил это руководство.
