Введение
Headlight bulbs in all cars will eventually be used up or burnt out. This will require these bulbs to be replaced.
Driving with one or both headlights not being functional could lead to accidents on the road. That is why cops pull people over for this very reason.
This guide will provide steps on how to replace these used up or burnt-out headlight bulbs. All you need is your hands and the right bulbs to get the job done.
Turn counterclockwise (1/4 of a turn) to remove the bulb and its attached plug from the socket.
Hold onto the bulb with one hand while holding down the clip at the bottom of the plug to remove the bulb.
3 участников успешно повторили данное руководство.
