Введение
I wanted more than anything to give my children a good Christmas so I bought my daughter new speakers for her car. Then in order to get me to install them I chose to create a fast fix guide. You will find comprehensive instructions here to install new speakers and amplifier into the trunk of a 2007 accord. It may seem daunting at first but take it one step at a time and remember anything can be overcome with hard work, a little know how, and a bunch of money.
  1. 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: step 1, image 1 of 3 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: step 1, image 2 of 3 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: step 1, image 3 of 3
    • Using plastic opening tools, remove the floor trim panel on the driver's side door.
  2. 2007 Honda Accord Bass Speakers Replacement: step 2, image 1 of 3 2007 Honda Accord Bass Speakers Replacement: step 2, image 2 of 3 2007 Honda Accord Bass Speakers Replacement: step 2, image 3 of 3
    • Remove the shifter frame panel with the same opening tools.
  3. 2007 Honda Accord Bass Speakers Replacement: step 3, image 1 of 3 2007 Honda Accord Bass Speakers Replacement: step 3, image 2 of 3 2007 Honda Accord Bass Speakers Replacement: step 3, image 3 of 3
    • Unclip the heated seats harnesses.
    • Remove the 12V power supply connection.
  4. 2007 Honda Accord Bass Speakers Replacement: step 4, image 1 of 3 2007 Honda Accord Bass Speakers Replacement: step 4, image 2 of 3 2007 Honda Accord Bass Speakers Replacement: step 4, image 3 of 3
    • Remove the cubby space to access the head unit.
  5. 2007 Honda Accord Bass Speakers Replacement: step 5, image 1 of 2 2007 Honda Accord Bass Speakers Replacement: step 5, image 2 of 2
    • Remove the center climate vents with the opening tools.
  6. 2007 Honda Accord Bass Speakers Replacement: step 6, image 1 of 3 2007 Honda Accord Bass Speakers Replacement: step 6, image 2 of 3 2007 Honda Accord Bass Speakers Replacement: step 6, image 3 of 3
    • Remove the head unit from the dash.
  7. 2007 Honda Accord Bass Speakers Replacement: step 7, image 1 of 3 2007 Honda Accord Bass Speakers Replacement: step 7, image 2 of 3 2007 Honda Accord Bass Speakers Replacement: step 7, image 3 of 3
    • Attach the wiring harness into the amp by clipping it in.
  8. 2007 Honda Accord Bass Speakers Replacement: step 8, image 1 of 3 2007 Honda Accord Bass Speakers Replacement: step 8, image 2 of 3 2007 Honda Accord Bass Speakers Replacement: step 8, image 3 of 3
    • Run the wires under the back seat and along the driver's side door sill (removed in step 1) to under the steering wheel.
  9. 2007 Honda Accord Bass Speakers Replacement: step 9, image 1 of 3 2007 Honda Accord Bass Speakers Replacement: step 9, image 2 of 3 2007 Honda Accord Bass Speakers Replacement: step 9, image 3 of 3
    • Find a spot to drill a hole through the firewall under steering wheel area in the footwell.
  10. 2007 Honda Accord Bass Speakers Replacement: step 10, image 1 of 3 2007 Honda Accord Bass Speakers Replacement: step 10, image 2 of 3 2007 Honda Accord Bass Speakers Replacement: step 10, image 3 of 3
    • Run the power and ground wires from the trunk through the door sill and through the firewall to the engine bay.
  11. 2007 Honda Accord Bass Speakers Replacement: step 11, image 1 of 3 2007 Honda Accord Bass Speakers Replacement: step 11, image 2 of 3 2007 Honda Accord Bass Speakers Replacement: step 11, image 3 of 3
    • Now run the power wire where it will be out of the way.
    • Run the power wire (red) and the ground wire (green) to battery, connect red to positive and green ground to a clean piece of the car body.
    • Make sure to leave the power wire off until finished.
  12. 2007 Honda Accord Bass Speakers Replacement: step 12, image 1 of 3 2007 Honda Accord Bass Speakers Replacement: step 12, image 2 of 3 2007 Honda Accord Bass Speakers Replacement: step 12, image 3 of 3
    • Remove the wiring harness from the back of the head unit.
    • Connect the four speaker wires and one remote wire to the harness as suggested in the owner's manual.
  13. 2007 Honda Accord Bass Speakers Replacement: step 13, image 1 of 3 2007 Honda Accord Bass Speakers Replacement: step 13, image 2 of 3 2007 Honda Accord Bass Speakers Replacement: step 13, image 3 of 3
    • Clamp down the wire harness on the five wires.
    • Tape up the wire loom to keep it neat.
    • Finally insert it back into the head unit.
  14. 2007 Honda Accord Bass Speakers Replacement: step 14, image 1 of 3 2007 Honda Accord Bass Speakers Replacement: step 14, image 2 of 3 2007 Honda Accord Bass Speakers Replacement: step 14, image 3 of 3
    • At last put the head unit, and the panels back into the car.
Заключение
To reassemble your device, follow the instructions in reverse order.
2 участников успешно повторили данное руководство.
Frankie
Участник с: 24.03.2021
253 Репутация
1 руководство автора
UMass Dartmouth, Team S1-G2, Riel Spring 2021 Участник UMass Dartmouth, Team S1-G2, Riel Spring 2021
UMASSD-RIEL-S21S1G2
1 член
Автор 1 руководств
0 Comments
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 31
За последние 30 дней: 121
За всё время: 1,204
