2008-2013 Subaru Forester Cabin Air Filter Replacement
Выберете то, что вам нужно
  1. 2008-2013 Subaru Forester Cabin Air Filter Replacement, Cabin Air Filter: шаг 1, изображение 1 из 1
    • Ensure the vehicle is shut off with the key removed from the ignition before you begin.
    • Open the glovebox located on the passenger side.
  2. 2008-2013 Subaru Forester Cabin Air Filter Replacement: шаг 2, изображение 1 из 2 2008-2013 Subaru Forester Cabin Air Filter Replacement: шаг 2, изображение 2 из 2
    • Unhook the glovebox retention arm from the side of the glovebox by squeezing the clip together with your fingertips, and prying the arm off the lower connection point only.
    • Gently push the arm up and half way in to prevent accidental breakage.
  3. 2008-2013 Subaru Forester Cabin Air Filter Replacement: шаг 3, изображение 1 из 2 2008-2013 Subaru Forester Cabin Air Filter Replacement: шаг 3, изображение 2 из 2
    • Starting on either the left or right side, insert screwdriver blade tip into the small catch ramp until it releases.
    • Repeat inserting screwdriver blade tip on opposite side of glovebox and catch ramp until both sides are released and glovebox falls freely open.
  4. 2008-2013 Subaru Forester Cabin Air Filter Replacement: шаг 4, изображение 1 из 2 2008-2013 Subaru Forester Cabin Air Filter Replacement: шаг 4, изображение 2 из 2
    • Remove the glovebox by pulling horizontally away from its (C shaped) hinge points.
  5. 2008-2013 Subaru Forester Cabin Air Filter Replacement: шаг 5, изображение 1 из 3 2008-2013 Subaru Forester Cabin Air Filter Replacement: шаг 5, изображение 2 из 3 2008-2013 Subaru Forester Cabin Air Filter Replacement: шаг 5, изображение 3 из 3
    • Open door to filter compartment to access filter.
    • Remove filter media.
    • Note orientation of filter for reinsertion.
Заключение
Finally, to reinstall the clean cabin air filter, simply follow these same instructions, but in reverse order.
Purchasing and replacing your own cabin filter is simple, time-saving, and resourceful. Congratulations on a job well done!
3 участников успешно повторили данное руководство.
Sean Mc
Участник с: 09/26/18
175 Репутация
1 руководство автора
Команда
Eastern Washington University, Team S3-G3, Crane Fall 2018 Участник Eastern Washington University, Team S3-G3, Crane Fall 2018
EWU-CRANE-F18S3G3
3 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 11
За последние 30 дней: 63
За всё время: 6,660
