Введение
The 2008-2013 Volkswagen Golf tail light bulbs may burn out over time. This replacement guide will instruct users how to locate, remove, and replace these light bulbs.
Выберете то, что вам нужно
On the driver's side of the vehicle's rear cargo area, locate the rectangular tail light compartment cover.
Using your fingers, gently pull the cover away from the compartment.
With the cover removed, locate the light bulb assembly.
Use a flathead screwdriver to release the locking tab.
Turn the assembly so that the smaller tail light bulb and larger fog light bulb are visible.
Using your fingers, gently pull the tail light bulb out of the socket.
Insert a new replacement light bulb into the tail light socket.
6 участников успешно повторили данное руководство.
