Введение
This is a guide for replacing both of your 2008-2010 Audi A3 Sportback hatch lift supports/struts. Upon successfully following instructions, your hatch should be able to support itself while fully open. See the troubleshooting page for this device.
Make sure you have an assistant who can easily hold the door open and will not grow faint or tired to ensure both peoples safety.
If you have an electrical connection (meaning if you can open your hatch with a click of a button) to the hatch door, be sure to disconnect it before starting the replacement process.
You must replace both struts, even if only one has failed. Replacing only one strut will cause an imbalance on the hatch door while opening and closing and could wear-down the new strut more quickly.
Do not scratch the metal part of the strut, it can affect it’s functionality.
Have all of your tools and parts ready to go before you start the replacement process!
The hatch lift support parts can be purchased here.
Выберете то, что вам нужно
Open the hatch and ask your helper to keep it open.
Start with the bottom connection of the strut. Slide the flat-head screwdriver into the slit and you should be able to easily slide it between the metal belt and the joint. Then remove the lower connection away from the ball joint.
Slide the flat-head screwdriver between the metal belt and the joint piece and gently push back the metal belt.
Once the belt is pulled back, pull the strut away from the ball joint connecting it to the car.
Pull the strut away from the lower ball joint and remove the strut, ensuring that your partner is holding the hatch door steady.
2 участников успешно повторили данное руководство.
