2008-2010 Mitsubishi Lancer Radio/CD Player Replacement
Выберете то, что вам нужно
  1. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement, 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 1, изображение 1 из 1
    • The only tool required for this install is a Phillips #2 screwdriver. Of course, you will also need the new replacement radio/CD player unit that you will be installing.
    • Make sure that the car is not on before proceeding since we will be accessing some electrical components. However, you do not need to disconnect the car's battery.
  2. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 2, изображение 1 из 2 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 2, изображение 2 из 2
    • Using both hands, apply inward pressure to the sides of the glove compartment until the compartment is free to slide out.
    • The clips on the side of the glove compartment must be freed.
  3. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 3, изображение 1 из 1
    • Remove the attached plastic arm by simply pulling outward so that the arm snaps out of its socket.
  4. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 4, изображение 1 из 2 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 4, изображение 2 из 2
    • The glove compartment can now be removed completely by raising it off its hinges.
  5. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 5, изображение 1 из 1
    • Using the Philips #2 screwdriver, remove a 15 mm screw located just above the glove compartment damper piston.
  6. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 6, изображение 1 из 1
    • Carefully remove the plastic trim by pulling outwards.
  7. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 7, изображение 1 из 1
    • Using a Philips #2 screwdriver remove a 15 mm screw from the trim piece.
  8. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 8, изображение 1 из 3 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 8, изображение 2 из 3 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 8, изображение 3 из 3
    • Using both hands, carefully pull the trim outward section by section.
    • The dashboard and decorative trim are attached to each other, so they will come out as one unit.
    • When pulling out the trim start from the right and work your way toward the center console.
  9. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 9, изображение 1 из 1
    • Optional: If you choose, you can remove the harness shown. (See directions on Step 12 for removing a harness clip.) Otherwise you can simply rest the fixture on top of the shift knob.
  10. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 10, изображение 1 из 1
    • Using a Philips #2 screwdriver remove four 12 mm screws attached to the mounting bracket.
  11. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 11, изображение 1 из 2 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 11, изображение 2 из 2
    • Pull out the radio unit to expose the connections behind it.
  12. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 12, изображение 1 из 2 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 12, изображение 2 из 2
    • Remove the black antenna connection by simply pulling it out.
  13. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 13, изображение 1 из 3 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 13, изображение 2 из 3 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 13, изображение 3 из 3
    • Remove both the large and small wire harnesses by firmly pressing in and holding the retaining clip.
    • While continuing to hold down the retaining clip, firmly pull the harnesses out.
    • Do not pull harnesses out by the wires, as you may damage or break the wires. Instead pull out by the white plastic harness.
  14. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 14, изображение 1 из 3 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 14, изображение 2 из 3 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: шаг 14, изображение 3 из 3
    • You are now ready to replace your radio with your new unit.
Заключение
4 участников успешно повторили данное руководство.
Carlos Esquivel
Участник с: 02/23/15
236 Репутация
1 руководство автора
Команда
Cal Poly, Team 12-1, Green Winter 2015 Участник Cal Poly, Team 12-1, Green Winter 2015
CPSU-GREEN-W15S12G1
6 членов
Автор 7 руководств
5 Комментариев
Thx. Saved me hrs of wrongful disassembly. Lol
Phil - Ответить
Any Mitsubishi radio code can be recovered for free by online generating tool : https://www.radiocodescalculator.com/mit...
Blaze Angelov - Ответить
Hi I own a 2008 Mitsubishi lancer just brought it CD player doesn't work only radio so wondering where I can buy a new stereo thanks. Or a way to fix mine it's like it's not working at all turn onto CD mode but won't even try read
JAD BLAXLAND - Ответить
Had the same problem with my 08 lancer. Replaced with a refurbished unit.
sanjurjo54 -
If you break some of the white clips like i did, the replacement part number from Mitsubishi is MR402859
gregshep - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 16
За последние 30 дней: 99
За всё время: 19,526
