Введение
Tired of driving with a broken radio in your Mitsubishi Lancer and you don’t want to spend a small fortune having it replaced at a dealership? Save yourself the labor costs and simply do it yourself following this step-by-step guide.
In this guide I will be replacing the radio unit for a 2008 Mitsubishi Lancer. The model and part number of the radio unit may vary with year.
The model/part number for the radio unit is: MN141319/DY-3W69U
This guide may not apply to models with Rockford Fosgate or navigation systems.
Выберете то, что вам нужно
The only tool required for this install is a Phillips #2 screwdriver. Of course, you will also need the new replacement radio/CD player unit that you will be installing.
Using both hands, apply inward pressure to the sides of the glove compartment until the compartment is free to slide out.
The clips on the side of the glove compartment must be freed.
Remove the attached plastic arm by simply pulling outward so that the arm snaps out of its socket.
The glove compartment can now be removed completely by raising it off its hinges.
Using the Philips #2 screwdriver, remove a 15 mm screw located just above the glove compartment damper piston.
Using a Philips #2 screwdriver remove four 12 mm screws attached to the mounting bracket.
Remove both the large and small wire harnesses by firmly pressing in and holding the retaining clip.
While continuing to hold down the retaining clip, firmly pull the harnesses out.
4 участников успешно повторили данное руководство.
5 Комментариев
Any Mitsubishi radio code can be recovered for free by online generating tool : https://www.radiocodescalculator.com/mit...
Hi I own a 2008 Mitsubishi lancer just brought it CD player doesn't work only radio so wondering where I can buy a new stereo thanks. Or a way to fix mine it's like it's not working at all turn onto CD mode but won't even try read
Had the same problem with my 08 lancer. Replaced with a refurbished unit.
