Введение
I've found zero tutorials or references online on how to do this. Hopefully, this simple tutorial helps people who wish to replace their OEM head unit.
Выберете то, что вам нужно
Use soft disassemble tools to remove the bezels hiding the screws.
Unscrew mounting plates from original headunit to custom headunit.
Screw the mounting plates on to your custom head unit.
Add the unit's bezel.
You will need an adapter from Suzuki's headunit connection to generic connection.
18 участников успешно повторили данное руководство.
8 Комментариев
Thanks for this, exactly what ive been looking for. I dont suppose you'd know the type of adapter necessary to connect the suzuki plug to an after market stereo? Thanks again for the guide!
Absolutely brilliant guide. Thanks. Had to purchase a different harness adaptor for my 14 alto sz3. It says on the packet the harness is for Honda Acc 9/98> but this fits and works 100%. Available from Halfords it is item PC2-68-4. Once again many thanks for the guide.
Thanks Jossef Harush for such a detailed guide. It really helps me a lot but at last due to some reasons the connection cable tear out and I have to reach out Gomechanic team for the replacement with a genuine wire. Love their service as well as your guide too.
Thanks so much for this guide.
We have removed the screws on the head unit but it will not pull out at all, it seems completely stuck. Any suggestions on how to remove it or something we are missing?
if you refer to the AC air vents then use more force, I’ve also experienced this.
can i fit any after market radio
