Введение
If you are experiencing poor braking performance and or a noise when braking, then it may be time to replace the rear brake pads and or rotor.
Follow this video tutorial by YouTuber NutzAboutBolts to complete the replacement yourself.
Depending on the Toyota Dealership Parts & Service Department; 3M Silicone Paste, 3M Copper Anti-Seize, Sil-Glyde or the Toyota caliper guide pin and anti-seize/squeal grease are recommended respectively.
Torque specs:
- 26 ft. lbs - Caliper sliding pin bolts
- 42 ft. lbs - Caliper bracket bolts
- 76 ft. lbs - Wheel lug nuts
Safety
If this is your first time working on a vehicle read our safety tips before proceeding.
Выберете то, что вам нужно
Видеоинструкции
Еще один человек закончил это руководство.
0 Комментариев
