Введение
When working on this repair, make sure you have the correct air filter for the car. To ensure you have the correct filter, run down to your local car repair shop (Napa Auto Parts or an O'Reilly's Auto Parts), they will help you identify the correct filter. This is a quick and easy repair that will save you money.
Выберете то, что вам нужно
Identify where the metal clips are on the side of the air filter container.
Unlatch both metal clips on the air filter container to open.
When the air filter container is open, remove old filter.
When the old filter is removed, wipe out container with a wet paper towel.
After you have replaced the new filter, close container and latch both metal hooks to close the container.
You have successfully changed an air filter in any 2009-2013 Mazda 3 model.
3 участников успешно повторили данное руководство.
