Введение
The door handle of a vehicle is prone to degrade overtime. This guide will help you with the car door replacement of a 2009 Kia Sorento. The tools used were a flat head screwdriver and socket wrench with a 10mm attachment.
Выберете то, что вам нужно
Before you can start removing the side panel, the speaker on the driver side door must be removed. To do this, simply squeeze and it will pop out. There is a little wire that connects the speaker to the car. To detach it there is a little button that can be pushed and it will come loose.
Once the speaker is out, six screws need to be removed to allow the panel to detach from the door.
After all the wires are detached and the door panel is set to the side, pull back the plastic seal to gain access to the bolts.
There are two bolts behind the plastic you just pulled back and one to the outer side of the car door behind a little plastic cover.
Use a socket wrench with a 10mm attachment to loosen the bolts. To remove the bolts on the inside of the door, just loosen the bolts with the socket wrench and then use your hands to remove it completely.
Now that the old door handle is fully detached from the car you can now put in your replacement part.
3 участников успешно повторили данное руководство.
2 Комментариев
I got up to "remove the white blocks (electrical) from the door panel". I couldn't get them out. Any suggestions?
I'm about to do this 2009 Kia Sorento LX both driver and passenger front handle replacement next weekend. I hope yours went well, wish me luck!!
MoniB -
