Введение
If followed, this guide for front door panel replacement will result in the successful removal of the front door panel. Allowing you to reach the interior parts of the door, or replace a broken panel.
Выберете то, что вам нужно
Pry up the plastic tab from inside the handle located on the front door armrest.
Use your Phillips screwdriver to unscrew the 8x3/4" Phillips screw by the upper door handle.
Unscrew the second 8x3/4" Phillips screw located inside the lower door handle on the door's armrest.
Pry off the entire door speaker and its housing located inside of the mirror.
Using your flathead screwdriver, pry up the latch connecting the two white cords and disconnect the speaker.
Using your flathead screwdriver, pry the middle plastic door piece away from the armrest.
Using your flathead screwdriver, press the white tab on the side of the larger cord bundle connecting the assembly.
The larger cord bundle now can be pulled out.
Press the white tab on the smaller cord bundle and disconnect the smaller cord bundle from the assembly.
Unscrew both 8x3/4" Phillips screws from the middle of the door panel using your Phillips screwdriver.
Pry the left side of the door panel away from the door using a flathead screwdriver.
It may be easiest to start by prying away where the red circle is located.
Using your hands now, pry the door panel away from the door.
You will hear a series of pops when the white tabs disconnect from the door.
Finish pulling the door off of the frame, now that all the clips have been disconnected.
Disconnect the final two power window cables that connect the door panel to the door frame by pulling both out of their sockets.
Congratulations! You are now done.
2 участников успешно повторили данное руководство.
