Введение
This guide will make use of a specific kit to install an aftermarket head unit (listed at required parts). Other solutions for connecting the Suzuki head unit interface to a standard aftermarket one are probably available as well.
Depending on the solution you have available, some installation steps might be slightly different.
Выберете то, что вам нужно
Use the door panel removal tools to pry open the top cover.
Place something underneath it, to prevent it falling back into place. There is no need to detach the cover cable and complete remove it.
Screw open the 2 top screws located at the red arrows. Use a magnetic tip for easy retrieval.
Use the door panel removal tools to pry it open from its 4 brackets.
Slowly remove the head unit from its enclosure and detach the cables.
Power, speaker output and steering wheel control.
USB input
antenna input
Fit your aftermarket head unit to the faceplate frame of the installation kit.
At (1), connect the stereo supplied power cable with the installation kit supplied adaptor cable.
At (2), strip the end of the steering wheel interface cable and crimp on the appropriate "key" cable from the universal interface.
At (3), disconnect the appropriate patch cables and prevent them from shorting.
At (4), connect both leads to the steering wheel input control box.
The harness you made (and the antenna adapter) can be connected to your aftermarket head unit and the Suzuki cable interface.
Reconnect the battery, turn on the car and the head unit and test if everything is working as it should be.
Make sure the clips (shown in the bottom two) are removed, or fit on the replacing faceplate frame.
Depending if and where you put some bolts on the replacing faceplate frame, cut out some of the plastic.
After that, you can click back your new head unit.
And finally, click back the top cover.
3 участников успешно повторили данное руководство.
6 Комментариев
Hi, I would like to know if the steering wheel interface is necessary because the suzuki buttons send the commands via CANBUS and the head unit only can be controlled by resistive type of buttons. Thank you.
Hi was this resolved? I’m seeing documentation for universal adapters suggesting they are already resistive and not canbus. I’m looking at a 2016 swift
Sean -
Hi,
Does the antenna need power, I bought an installation kit and not he antenna adapter there is a blue wire, i assume this needs to be connected?
Not sure I connected the blue antenna cable from the kit. It mentions on the product site as a "DIN Antenna Adapter With Phantom Power Supply", so my guess would be no (https://connects2.com/Product/ProductIte...).
knipwim -
No this is for an old fashioned retractable aerial - these days it's a useful 12v trigger for an amp.
