Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows you how to remove a wheel and then reattach it for a 2010-2014 Ford Mustang.
Follow these guidelines to prevent harm to yourself or to others.
- Park the car on a firm and level surface.
- Turn off the engine and engage the emergency brake.
- The hydraulic jack should be in a good-working condition.
- The wheels should always be taken off one at a time when using a hydraulic jack.
Выберете то, что вам нужно
Place the hydraulic jack under the metal frame of the car near the tire that you want to change.
Pump the jack handle evenly until the tire raises only an inch or two off of the ground. Be sure not to lay underneath the vehicle until the new wheel is properly installed.
Lug nuts hold the wheel in place. Use the 13/16" socket with a breaker bar to remove the lug nuts by turning the nuts counterclockwise.
Grab the wheel with both hands and pull the wheel straight off and away from the car.
Place a new wheel on the hub, and then fix it in place by tightening the lug nuts clockwise. In other words, skip every other nut as you go around the wheel.
Follow these instructions in reverse order to reassemble the wheel back to the vehicle.
5 участников успешно повторили данное руководство.
Один комментарий
I have found it to be better to loosen the wheel nuts before you jack up the car. Also, when replacing the wheel nuts, these must be torqued to the proper value. This requires the use of a torque wrench. Consult your manual for the proper torque on the wheel nuts.
