Введение
Replacing the door handle of your 2010 Chevrolet Camaro is necessary when the door handle becomes damaged, cannot function correctly, or wears out over time. The handle can be expensive to replace if taken to professionals to fix at a dealership.
Additionally, replacing your malfunctioning interior door handle successfully can prevent being locked out of your vehicle. Replacing it yourself saves both money and time. The kits sold to replace the interior door handle make it very convenient to replace it with little to no time and minimal tools.
Once you’ve finished with your replacement, make sure to test out the handle to verify that it works.
Выберете то, что вам нужно
Рекомендуемый документ
Remove the five bolts that connect the door panel to the door using the T30 Torx screwdriver.
Use a door panel removal tool to pry out the outer edges.
Use your hands to sisconnect the speaker cables from the door panel.
Set the door panel aside.
Grab the replacement interior door handle.
Use the T30 Torx screwdriver to remove the single screw holding the original door handle in place.
Remove and replace the broken door handle the same as you disassembled it.
Using the 7mm deep socket and a racketing wrench, remove the screws connecting the door panel to the handle.
Replace the door handle.
Screw the three 7mm screws back into place.
Double check the connection to the door handle.
Inspect the new door latch to ensure it is working.
Check that the door is working properly.
Reinstall the door panel by completing Step 1 in reverse.
Reconnect all the cables.
The interior door handle replacement functions the same as the original.
You have now successfully replaced a 2010 Camaro interior door handle.
To reassemble your device, follow these instructions in reverse order. Test out the door handle and if it functions the same as the original door handle.
