2010 Jeep Liberty Headlight Bulb Replacement
Выберете то, что вам нужно
  1. 2010 Jeep Liberty Headlight Bulb Replacement, Headlight Bulb: шаг 1, изображение 1 из 1
    • Pop the hood of your vehicle by pulling the lever near the bottom of the driver's side door.
    • Slide your hands under the unlatched hood to find the second lever. Push this lever to the right and lift the hood.
    • Be sure to use the hood prop to keep the hood from falling while you're underneath it.
  2. 2010 Jeep Liberty Headlight Bulb Replacement: шаг 2, изображение 1 из 3 2010 Jeep Liberty Headlight Bulb Replacement: шаг 2, изображение 2 из 3 2010 Jeep Liberty Headlight Bulb Replacement: шаг 2, изображение 3 из 3
    • Identify the bulb socket, located behind the headlight.
    • Rotate the base of the bulb counter-clockwise to remove it from the socket.
    • Remove the bulb from the green base by pulling the two apart.
  3. 2010 Jeep Liberty Headlight Bulb Replacement: шаг 3, изображение 1 из 3 2010 Jeep Liberty Headlight Bulb Replacement: шаг 3, изображение 2 из 3 2010 Jeep Liberty Headlight Bulb Replacement: шаг 3, изображение 3 из 3
    • Insert the new bulb into the green base.
    • Be sure not to touch the glass with your fingers. If you do, wipe the bulb down with a soft cloth and some rubbing alcohol. Oils left behind from your fingers can shorten the life of the bulb.
    • Rotate clockwise to lock the bulb assembly into the socket.
  4. 2010 Jeep Liberty Headlight Bulb Replacement: шаг 4, изображение 1 из 1
    • Turn on headlights to ensure the new bulb is working properly.
    • You will want to check that your headlights are aligned on both sides. Adjust as needed.
Заключение
Congratulations! You have a shiny new headlight.
8 участников успешно повторили данное руководство.
Ryan Griffin
Участник с: 01/19/16
245 Репутация
1 руководство автора
Команда
Oakland University, Team 6-1, Walwema Winter 2016 Участник Oakland University, Team 6-1, Walwema Winter 2016
OAK-WALWEMA-W16S6G1
10 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 12
За последние 30 дней: 45
За всё время: 8,958
