Введение
Headlights are among one of the most important safety devices on a vehicle. They provide you with light to see when it gets dark, as well as be seen by other drivers. This guide is going to demonstrate how to safely and easily replace a headlight bulb on a 2010 Jeep Liberty.
Выберете то, что вам нужно
Pop the hood of your vehicle by pulling the lever near the bottom of the driver's side door.
Slide your hands under the unlatched hood to find the second lever. Push this lever to the right and lift the hood.
Identify the bulb socket, located behind the headlight.
Rotate the base of the bulb counter-clockwise to remove it from the socket.
Remove the bulb from the green base by pulling the two apart.
Insert the new bulb into the green base.
Rotate clockwise to lock the bulb assembly into the socket.
Congratulations! You have a shiny new headlight.
8 участников успешно повторили данное руководство.
