Введение
Rear dome light bulbs go out in cars and it's convenient to have them light up when needed. Simply replacing the bulbs will solve the problem and allow backseat riders to utilize light when it's dark out.
Выберете то, что вам нужно
Use one hand to push up on the roof surrounding the plastic cover and utilize a flathead screwdriver to gently pry out light fixture and cover.
Starting with the 2 clips on each side of the light, remove the 10 clips on the fixture.
Using hose pliers, pull out the bulb being replaced.
Now, insert new bulb by securing it into socket and pushing into place.
Finally, test the new lights by turning them on and off a few times for 30 seconds or so to assure they work properly.
Еще один человек закончил это руководство.
