2010 Toyota Camry SE Dome Light Bulbs Replacement
Выберете то, что вам нужно
  1. 2010 Toyota Camry SE Dome Light Bulbs Replacement, Dome Light Bulbs: шаг 1, изображение 1 из 1
    • Use one hand to push up on the roof surrounding the plastic cover and utilize a flathead screwdriver to gently pry out light fixture and cover.
  2. 2010 Toyota Camry SE Dome Light Bulbs Replacement: шаг 2, изображение 1 из 1
    • Starting with the 2 clips on each side of the light, remove the 10 clips on the fixture.
    • The user should loosen every clip before removing fixture.
  3. 2010 Toyota Camry SE Dome Light Bulbs Replacement: шаг 3, изображение 1 из 1
    • Once the clips are loose, pop off the plastic cover grey plastic cover.
  4. 2010 Toyota Camry SE Dome Light Bulbs Replacement: шаг 4, изображение 1 из 1
    • Using hose pliers, pull out the bulb being replaced.
    • Now, insert new bulb by securing it into socket and pushing into place.
  5. 2010 Toyota Camry SE Dome Light Bulbs Replacement: шаг 5, изображение 1 из 1
    • Reinstall plastic light fixture by pushing cover back into place.
    • Fixture should easily snap back in with proper placement.
  6. 2010 Toyota Camry SE Dome Light Bulbs Replacement: шаг 6, изображение 1 из 1
    • Finally, test the new lights by turning them on and off a few times for 30 seconds or so to assure they work properly.
    • If they do not work then the next suggestion would be to check the fuse box before heading to the dealer.
    • Sometimes fuses blow out which can be spotted by careful analysis. If two parts of the fuse do not meet such as disconnected wires then you have a blown fuse.
Финишная черта
Еще один человек закончил это руководство.
Gabriel Durazo
Участник с: 01/28/18
160 Репутация
1 руководство автора
Команда
Eastern Washington University, Team S27-G3, Crane Winter 2018 Участник Eastern Washington University, Team S27-G3, Crane Winter 2018
EWU-CRANE-W18S27G3
3 членов
Автор 4 руководств
Один комментарий
Hi, Thank you for posting this repair solution. Do you think it'll be easy to replace the entire assembly? My bulbs work, but the buttons don't stay on. Thanks.
KPW - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 25
За всё время: 2,722
