Введение
This step-by-step guide demonstrates how to repair a driver-side front pillar trim of a Ford Explorer 2013 XLT though you can use it for your fifth-generation Ford Explorer, years 2011-2019.
When the front pillar trim is cracked, deteriorated, broken, or installed incorrectly it can pose a safety risk as it supports the front windshield. This guide is useful in repairing the front pillar trim of a Ford Explorer 2013 XLT.
Выберете то, что вам нужно
Gently apply even force to separate the exterior pillar trim from the interior pillar trim.
Use a ratchet socket and an 8 mm socket attachment to remove the six bolts from the interior pillar trim.
If there is a small tab attached at the upper corner, detach it by gently lifting and separating it from the trim.
Remove the damaged interior pillar trim and clean surrounding areas.
Use a rag and glass cleaner to clean the pillar trim area.
Remove any remaining residue from the window and metal. Use as much window cleaner as necessary.
Align the new interior pillar trim part precisely with the corresponding holes on the vehicle.
Ensure they are aligned precisely and apply pressure.
While maintaining downward pressure on the interior pillar trim, secure the six bolts into place.
Align the small white head connections with the yellow points on the exterior trim, and then firmly snap the push tabs into place to secure the trim.
Еще один человек закончил это руководство.
