Введение
If the internal car door handle is broken on your 2011 Hyundai Vera Cruz, use this guide to replace the door handle and locking mechanism. Without a functional door handle, the car door might be unable to open from the inside or the outside.
Выберете то, что вам нужно
After removing all four screws, remove the small triangular plastic piece above the door panel by using a flat head screwdriver and prying the piece up.
Using a flathead screwdriver, remove the door panel by prying it off the door frame
Once the door panel is completely off, the electrical connection in the door frame must be disconnected and removed.
After removing the electrical connection, the locking mechanism of the door handle must be removed. This can be done by pressing the tab located on the back of the door handle mechanism.
After the door panel is fully disconnected, it should be set on a flat surface with the screw side face up.
Then, the five screws holding the door handle to the door panel must be located and unscrewed.
The new locking mechanism can be connected in the same place the old one was removed from.
Еще один человек закончил это руководство.
