Введение
This guide will help you replace the air filter on your 2011-2014 Dodge Challenger 3.6L V6 by locating the air filter housing, using a screwdriver or clips to open it, removing the old filter, cleaning the housing if necessary, inserting the new filter with the correct orientation, sealing the housing securely, and checking for a snug fit. Don't forget to dispose of the old filter and record the replacement date.
Выберете то, что вам нужно
Pop The Engine Hood Open
Reminder- Hood Latch Release is Under the Steering Wheel
Locate The Air Intake In Engine Bay
Hint- Should be on the Lower Right-Hand Side
Using A Flat Head Screwdriver Remove All 3 Screws Holding In the Air Intake Cover
Reminder All 3 screws are the same size 12mm no need to keep track of where they go
Using the FlatHead screwdriver Loosen the clamp holding in the Air Intake
Tip- Do not fully remove the clamp Just Loosen it
Remove AIr Intake Lid
Tip- Place Intake Lid Above the Intake to not Loosen Hose Going to the Intake
Reapply all 3 Screws For the Intake Lid
Tighten the Clamp on the Hose Going to the Intake
Now you Have Completely Replaced Your car's Engine Air Filter.
Еще один человек закончил это руководство.
