Выберете то, что вам нужно
Begin by opening the hood of the car and locating the battery on the front of the driver side in the engine compartment
Using a socket wrench, loosen the 2 (5/16 inch) nuts on the top of the battery support bracket
Remove the bracket by lifting up
After removing the bracket, locate the supporting rod behind the battery
The rod is hooked on a hole in the metal behind the battery. Unhook the rod and remove it
Start with the negative terminal of the battery
Loosen the nut on the negative terminal with a 10mm socket wrench
Remove the wire by slightly twisting and pulling up
Remove the cap from the positive terminal of the battery
Using a 10mm socket wrench, loosen the nut on the positive terminal
Remove the wire from the positive terminal by slightly twisting and pulling up
Remove the battery by lifting it out of the engine compartment
Еще один человек закончил это руководство.
