2011-2013 Scion tC Oil/Oil Filter Replacement
Выберете то, что вам нужно
  1. 2011-2013 Scion tC Oil/Oil Filter Replacement, Oil/Oil Filter: шаг 1, изображение 1 из 1
    • Open the spare tire compartment in the trunk of the vehicle by pulling up on the black tab.
    Спросите у FixBot
    Добавить комментарий
  2. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 2, изображение 1 из 1
    • Locate the manufacturer supplied jack and jack handle in the spare tire compartment; these will be needed for the replacement.
    • This is an emergency jack, and is not safe to use for routine maintenance. Use a floor jack with a weight rating appropriate for your vehicle.
    Спросите у FixBot
  3. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 3, изображение 1 из 1
    • Place the jack approximately 2 feet behind the passenger wheel tire at the shown location. Finger tighten the jack until snug against the frame.
    • It's best to avoid using the jack included with the car. If at all possible, use at least a 2 ton floor jack.
    Спросите у FixBot
  4. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 4, изображение 1 из 1
    • Place the jack handle in the jack to begin lifting the car.
    Спросите у FixBot
  5. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 5, изображение 1 из 1
    • Using two hands, turn the jack handle clockwise and raise the car.
    Спросите у FixBot
  6. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 6, изображение 1 из 1
    • Raise the car until the jack stand can fit underneath the frame. Place the jack stand under the frame as close to the jack as possible.
    Спросите у FixBot
  7. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 7, изображение 1 из 1
    • Lower the car onto the jack stand by turning the handle counterclockwise. Remove the jack once the load is taken off.
    Спросите у FixBot
  8. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 8, изображение 1 из 1
    • Once the jack stand is securely in place locate the engine oil drain plug. This is most accessible by crawling on your back from the front of the car.
    Спросите у FixBot
  9. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 9, изображение 1 из 1
    • Using the 14mm socket wrench, loosen the drain plug by turning counterclockwise until you can turn the plug by hand.
    • Be careful not to loosen all the way to avoid spilling oil.
    Спросите у FixBot
  10. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 10, изображение 1 из 1
    • Once the plug is slightly loose, place the oil drain pan underneath the plug, remembering to account for the arc of the stream when placing the oil pan.
    • Continue to loosen the plug until oil begins to flow.
    Спросите у FixBot
  11. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 11, изображение 1 из 1
    • Allow oil to drain freely until drops of oil are slowly coming from the drain. Then re-tighten the oil drain plug using the 14mm socket wrench.
    • Do not over-tighten the drain plug. Only apply approximately 20 lbs to the end of the wrench.
    Спросите у FixBot
  12. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 12, изображение 1 из 1
    • Locate the oil filter. This is most accessible on your back from the front of the car. The filter should be about a foot closer to the front of the car from the oil drain plug.
    Спросите у FixBot
  13. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 13, изображение 1 из 1
    • Using the 3/8 inch socket wrench with extension, loosen the oil filter by putting the extension in the square hole in the filter and turning counterclockwise.
    Спросите у FixBot
  14. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 14, изображение 1 из 1
    • Place the oil drain pan directly under the filter. Fully loosen the filter by hand until you are able to remove it from the vehicle.
    Спросите у FixBot
  15. 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 15, изображение 1 из 3 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 15, изображение 2 из 3 2011-2013 Scion tC Oil/Oil Filter Replacement: шаг 15, изображение 3 из 3
    • Remove the paper filter from the filter cartridge; this is disposable. Use the flathead screwdriver to pry the o-ring off the cartridge.
    Спросите у FixBot
Заключение
Replace the oil filter with a new one. Once reinserted into the filter housing, relube the o-ring with some fresh oil and reinstall on the filter housing. To reassemble your device, follow these instructions in reverse order.
5 человек успешно провели ремонт по этому руководству.
Lucas
Участник с: 05/07/15
223 Репутация
1 руководство автора
Команда
Cal Poly, Team 8-2, Regan Spring 2015 Участник Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 членов
Автор 7 руководств
1 Комментарий к руководству
That 3/8” extension removes a plug that allows for clearing the oil from the filter before removal. this does not remove the filter housing.
th4tguy - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 27
За последние 30 дней: 99
За всё время: 29,612
