Введение
This guide provides instructions on how to change your BMW Series 3 cabin air filter. Cabin air filters usually need replacement within 15,000 - 30,000 miles. An unchanged air filter is harmful to one's health so it is important to replace.
This repair requires a filter with dimensions 32.8in x 6.18in x 1.1in. The size of the cabin air filter varies between car models. Be sure to check your car model for the correct filter size.
Выберете то, что вам нужно
Open driver side door.
Lift the car hood lever until you hear your hood release.
Slide your hand under the hood and lift it up.
Using the socket wrench, start unbolting all six external bolts.
Release the cabin air filter from the hood.
Place the cabin air filter under the hood.
Screw in all six external hex screws back into place using the socket wrench.
2 участников успешно повторили данное руководство.
