Введение
Have you noticed that your AC isn’t outputting what it used to, or have you really been feeling the summer heat? Maybe you need your refrigerant replaced! Recharging your air conditioning is easy to do yourself, and the payoff is immediate! This guide shows you how to replace your air conditioning’s refrigerant in the 2011 Ford Focus and your car back to feeling the way it used to. Before you start, your vehicle should be at room temperature, and proper care should be taken for your safety.
Be sure to place your car in park and engage the parking brake.
Выберете то, что вам нужно
Connect the nozzle and hold the canister at a 3 o'clock angle.
Lock and remove the canister if it is around 40 to prevent it from going to 50 psi.
Finally, start up the car. If the air conditioning is cooler, you'll know that it works!
Еще один человек закончил это руководство.
