Введение
This guide is for base model Mazda 3 owners who need to replace their factory OEM door speakers.
Perform this repair while the car is off.
The speaker in this guide is a component speaker, so they do not require any wire cutting or soldering.
Выберете то, что вам нужно
Pry the door handle cover upwards using a flathead screwdriver.
Remove the cover to expose the screw.
Pull the door handle towards you.
Insert a small flathead screwdriver between the lock and the plate.
Pry the plate off by applying leverage away from the lock, exposing the second screw.
Инструмент, используемый на этом этапе:Heavy-Duty Spudger$4.99
Pry the door cover away from the frame using a heavy-duty spudger.
Push the switch panel out from the inside of the door cover.
Remove the wires connected to the panel by pressing the clips and pulling them outward.
Remove the door cover.
Use a Phillips #1 screwdriver to remove the four screws that secure the door speaker.
Remove the wires connecting the speaker by pressing the clip and pulling it outward.
3 человек успешно провели ремонт по этому руководству.
