Введение
Dodge Charger Key fobs are known to have their battery drained quickly. If your key fob stops working and you're unable to get into your car, don't worry! Most like, you just need to replace the battery. Though we used a 2017 Dodge Charger key fob to demonstrate, this guide should be applicable for 2011-Present Dodge Charger key fobs. When following this guide, do not use too much force as it may result in breaking your key fob.
Выберете то, что вам нужно
Pull the inner key from key fob.
Remove the key chain or any accessories for easy access to key fob.
Insert the new key fob battery into the holder.
You will hear a click sound when you push it into the holder.
Reassemble the key fob covers.
Press down around the edges to ensure the key fob is securely assembled.
Slide the car key into key fob.
