2012-2015 Honda Civic Taillight Turn Signal Replacement
Выберете то, что вам нужно
  1. 2012-2015 Honda Civic Taillight Turn Signal Replacement, Taillight Turn Signal: шаг 1, изображение 1 из 2 2012-2015 Honda Civic Taillight Turn Signal Replacement, Taillight Turn Signal: шаг 1, изображение 2 из 2
    • Ensure your car is turned off by checking that the key is in the off (O) position and that the engine is not running.
    • Open the trunk by pulling the latch on the floor of the driver's side.
  2. 2012-2015 Honda Civic Taillight Turn Signal Replacement: шаг 2, изображение 1 из 2 2012-2015 Honda Civic Taillight Turn Signal Replacement: шаг 2, изображение 2 из 2
    • In the trunk, remove these fasteners by prying the center piece out with the screwdriver.
    • Expose the bulbs by pulling the trunk lining away from the walls of the trunk.
  3. 2012-2015 Honda Civic Taillight Turn Signal Replacement: шаг 3, изображение 1 из 2 2012-2015 Honda Civic Taillight Turn Signal Replacement: шаг 3, изображение 2 из 2
    • Rotate the turn signal socket ¼ turn counterclockwise. The turn signal socket is located below the main taillight bulb and closer to the middle of the car.
    • You will be able to pull the socket out of its housing and expose the blown bulb.
  4. 2012-2015 Honda Civic Taillight Turn Signal Replacement: шаг 4, изображение 1 из 2 2012-2015 Honda Civic Taillight Turn Signal Replacement: шаг 4, изображение 2 из 2
    • Remove just the blown bulb from the socket. A bit of force might be required to get it separated, but once it is, just the bulb and its rectangular, flat base should remain.
    • Put the new bulb in.
Заключение
The fasteners are easiest to reinstall when the center piece is pulled as far out as possible when reinserting. Once they are back in place, press the center piece down to lock them in.
Keaton Gilbert
Участник с: 03/31/20
109 Репутация
1 руководство автора
Команда
University of Memphis, Team S4-G24, Willis Spring 2020 Участник University of Memphis, Team S4-G24, Willis Spring 2020
UM-WILLIS-S20S4G24
1 член
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 22
За последние 30 дней: 116
За всё время: 2,937
