Введение
Use this guide to replace a broken 2004-2013 BMW 3 Series windshield wiper. This guide will assist you in achieving your task in a straightforward and proper manner. To avoid damage, make sure you follow each step precisely for the best results. This repair procedure does not require the use of any specific tools or skills.
Выберете то, что вам нужно
To begin, open the hood and make sure the broken wiper's body is completely positioned on the hood.
Use a back and forth motion to carefully remove the wiper blade from the wiper arm. and then pull it out.
Install the replacement wiper so that the slightly bent angle side faces the vehicle.
Check that the screw is aligned with the hole.
With a little pressure, slowly slide the new wiper into place.
Once it is positioned correctly, lock the cover to keep the blade in place.
Lower the windshield wiper carefully onto the windshield.
Finally, test your wiper blades by spraying water or windshield wiper cleaner over your windshield and turning on the wipers.
