Введение
Full replacement of a Driver side mirror on a 2012 Nissan Murano, SL options package.
Выберете то, что вам нужно
Pull out the Driver preset panel, if your options package included this. Usually no tools required.
Pry out the door lock and window control panel. Disconnect all connectors on the back side.
Now you can remove all three hidden screws with the 10mm socket or philips screw driver.
Now the door panel itself can be pried off the door. Starting at the bottom, find the plastic friction plugs and pull enough to pop them out one by one.
Then lift the door panel up off the door. You do not need to remove it completly. This should give you enough room to work on the mirror in the next steps.
Remove the three nuts holding the mirror on to the door. Depending on the age of your vehicle, you may want to clean off the remaining area so the new mirror seals good.
3 участников успешно повторили данное руководство.
