Введение
This guide will take you through how to swap out the engine air filter in your 2013-2016 Scion FR-S (aka Toyota gt86.) A dirty air filter can cause your car to lose power and reduce the miles per gallon.
Dealerships recommend that you replace the engine air filter every 15,000-30,000 miles, depending on the driving conditions.
Выберете то, что вам нужно
Pull the handle located near the driver's left leg to unlock the hood.
Pull the secondary latch located to the right of the emblem.
Prop up the hood.
Grab the back of the box and pull it towards the top.
To pull out the air-filter, simply pull it away from the car and lift up.
Line up the little pins on the cover of the box with the base of the box in order to close it.
Clip the pins back in and you're done!
Now that the new filter is installed, you're good to go.
