Введение
This guide will show you how to change a damaged or worn out windshield wiper for a 2013 Dodge Charger as quickly as possible. This guide can be useful to anyone that has broken windshield wipers or has wipers that just aren’t working properly anymore. You will follow easy step by step instructions to ensure everything goes smoothly. My guide is useful for anyone that is new to changing windshield wipers and is in need of a repair. There are many different brands and sizes of windshield wipers so make sure to check your car manual to see which one works best for you!
Pull the wiper blade arm away from windshield until it is locked in place and pointing directly away from the windshield.
Push the wiper blade down the arm (directly toward the windshield).
Once the clip on the windshield wiper clears the hook on the arm, your windshield wiper is completely removed.
Position the new blade so the hook is pointing at the wiper attachment.
The hook will go over the top of the attachment.
Pull the blade down toward the end of the arm until it passes the hook.
Push the blade up into the hook until you hear a click. This tells you that the wiper is into position.
2 участников успешно повторили данное руководство.
