Введение
Experts recommend checking wipers every six months to make sure they are properly functioning, and when they are not, they need to be replaced. Wipers can also become aged, and they need to be replaced when the rubber is falling off and begins to scratch your rear window when using your wipers.
Выберете то, что вам нужно
Using your thumb, push the wiper away from you and out of place. You will hear it click when it is coming off.
Position the new blade to where it aligns perfectly with the existing wiper arm.
Place your thumbs on the top of the wiper and your other fingers on the under side of the wiper, to put the wiper into place.
You will hear it click when it is locked into place.
Test out the new wiper.
Turn your car on and switch your wiper on. The new blade will fall off of the wiper arm if it is not fully attached. If it is fully attached, the wiper will work successfully.
3 участников успешно повторили данное руководство.
Один комментарий
Thanks for this...all other videos were wrong. I needed the step by step pics.
