Введение
Changing the oil in any motor is a vital part to keep it running smoothly. Before changing the oil in your 2014 Honda CTX 700NA, make sure the engine is cool, if you just got done riding wait 15 minutes. The reason to wait for it to cool is because the exhaust pipe is also routed underneath the bike and can easily be mistakenly touched.
Выберете то, что вам нужно
Open the oil reservoir cap, located on the right side of the bike just behind the foot peg.
Once the bolt is removed the oil will drain out. Let all of the oil drain into the oil pan.
Once the new oil filter is installed, return to the oil reservoir mentioned in step 1. Insert a funnel and begin pouring in new oil, the type of oil required is SAE 10W-30.
2 участников успешно повторили данное руководство.
