Введение
Use this guide to replace the cabin air filter in your 2015-2023 Mustang. Regularly changing out your cabin air filter helps prevent pollutants from finding their way into your car. When your cabin air filter gets dirty and clogged, your air conditioner has to work harder to send cold air inside the car. This can make your air conditioning less effective and lead to a bad smell in your car. This is why it is important to change your cabin air filter regularly.
Make sure your car is off before you begin.
Выберете то, что вам нужно
Look to the right side of the glove box to find a lever. Pull up on the lever and then push it to the right. The lever should pop right off.
With a hand on either side, push inward from the sides of the glovebox. This will allow the glovebox to fall down completely, giving us access to the cabin air filter.
Lift up the little flap and look closely, you will see a little T20 Torx screw that is holding the air filter cover in place.
Gently pull down on the cover to reveal the air filter.
Gently remove the cabin air filter and put in your new one.
