Введение
If the brake light for your 2015 Ford Focus is not turning on when the brake is pressed, it is likely due to a burnt-out brake light.
This process does not require any additional tools besides a new LED light bulb. Repairing a tail light is a relatively simple process that people can accomplish at home.
Working with light bulbs instills a small risk of injury. Make sure that your car is off, the parking brake is engaged, and nothing is pressing on the brake to avoid injury.
Выберете то, что вам нужно
Find the black panel located behind the brake light in the trunk and remove the panel by sliding it off with a small amount of force with your hands.
Remove the exterior light panel by sliding it off with a small amount of force with both hands.
Twist the light bulb socket a quarter turn to the right to take out the light bulb compartment.
Еще один человек закончил это руководство.
