Введение
Is your purge valve not working?
Use this guide to help you replace the purge valve in less than 20 minutes. No major work needs to be done; you only need a cross-screwdriver and WD-40 to help you loosen some parts.
Ensuring that this component is operating correctly is crucial, as a malfunction can cause various problems, such as decreased fuel efficiency, increased emissions, and potentially even engine damage. This is why it is crucial to replace a faulty purge valve as soon as possible.
Выберете то, что вам нужно
Locate the purge valve on the engine. It is on the exhaust manifold near the cylinder head. It may have a round plastic gas cap at one end and a flange with an electrical connector at the other end.
Use a Cross slot/Phillips screwdriver and take out the screw that is used to hold the purge valve in place. Rotate the screwdriver to the left until the screw is fully out.
Disconnect the electrical connector from the purge valve by gently pulling it away from the valve.
Apply a few drops of WD-40 at the bottom and right hose to loosen them and make removing them more manageable.
You should be able to remove the hose's by hand but use a slip joint pillar if it is difficult. The hose's should then simply slide off and in doing so gently lift the valve away from the engine.
Now that you have removed the part, you may connect the new purge valve of your choice.
