Введение
This guide will walk you through the short and easy steps of replacing an expired brake light bulb in your 2016-2021 Camaro. A flat-head screwdriver and set of pliers are highly recommended for the repair, but not necessary. A new bulb will be needed to replace the old one.
Выберете то, что вам нужно
Using either the button on your vehicle's key fob, or the button on the driver's side door, open the trunk.
Go to the rear of the vehicle and lift the rear trunk lid until it reaches its highest position and locks out.
Using a spudger, gently pry the covers for the pop-rivets out.
Remove the pop-rivets themselves by inserting a spudger underneath them and prying up.
After the fastener caps have been removed, twist the knob on top of the cover counterclockwise to remove it.
With the housing assembly open, gently lift the housing cover from the taillight assembly and set it aside.
Locate the reverse bulb socket; it will be identifiable by a wire running from the back of the tail light.
Gently grab the reverse bulb socket with your pliers, then gently turn it counterclockwise for one-quarter of a rotation.
Pull the socket out from the assembly, and pull out the old bulb.
Insert your new bulb by gently pressing it into the socket.
Еще один человек закончил это руководство.
