Введение
This guide is a fairly easy fix for the 2016 Dodge Dart SXT that doesn’t require much technical knowledge about the car. Many automotive stores will usually lend out the tools needed for these types of repairs. When working with any electrical system within a car, make sure to properly disconnect the car battery before proceeding with any repair. Even with low risk systems like the dome lights, it ensures your safety and mitigates all risk of electrical shock. After this procedure, reconnect the battery, and all the lights should work as normal.
Выберете то, что вам нужно
Use a spudger to gently pry down on the clear plastic covers until they pop off.
Use a spudger to pry off the silver reflective pieces within the socket housing.
Gently push the new bulbs into the sockets, making sure not to damage the embedded wire leads.
Replace the silver inserts and clear covers by pushing the clips back into their respective slots.
Reconnect the car battery.
Test each light to ensure the bulbs are properly connected and light up by clicking each one on and off several times.
The newly replaced dome lights should retain all prior functionality, turning on when a door is opened or by pressing on the cover itself.
