Введение
Windshield wipers should get changed almost every six months based on usage. When the blades get damaged, it can cause a lack of visibility due to not contacting properly with the windshield surface. Here are a few easy steps for changing and replacing the 2016 Jeep Cherokee windshield wiper on your own.
Выберете то, что вам нужно
If the broken wiper is located on the passenger side, then you will need to purchase an 18-inch wiper.
If the damaged wiper is located on the driver side, then you will need a 26-inch wiper.
Most blades are held in place with a tiny clip.
Push that clip up, while you are pushing the blade backwards.
Once you get the blade free from the hook, push the blade down to disconnect it.
After disconnecting the old wiper, position the new blade so that the hook points toward the area where you just detached the old wiper.
