Введение
If your 2016 Nissan Altima key fob isn't having a quick response as before, or isn't working whatsoever, use this guide to replace the battery.
They key fob means everything to your Nissan Altima; a key fob with no battery will not allow you to enter nor start the vehicle.
Step 3 requires you to remove the battery from device. Make sure to not touch any component inside with your hands.
Выберете то, что вам нужно
Slide the little switch up on the back of the key. While doing so, remove the physical key that is stored inside the fob by pulling away.
Insert a flathead screwdriver or prying tool into the small notch located at the bottom of the key fob.
Carefully rotate the flathead counterclockwise to pry apart the two halves of the fob.
Pry out the battery with a flathead to avoid skin contact with electrical components.
Line up the parts in order to secure the key.
Press down until the case makes a "click" sound.
Finally, insert the physical key back into the fob to complete your replacement.
4 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Great job , thanks . Sent wife info and believe it she figured it out, thanks.
