Введение
Use this guide to replace your brake light for 2016 Nissan Versa.
Brake lights are compulsory safety component of your car and are legally required to be functioning whenever your vehicle is operational. This guide will provide an easy-to-follow instructions to replace this vital safety component.
Before beginning, make sure to switch off your car.
In step 5, you will need to begin prying the lens from the tip before pulling it out completely. It will be the same when you are putting the lens back on. You will need to snap the plastic tip in first in step 11 before pushing the rest of the lens in.
Выберете то, что вам нужно
Turn off the vehicle and let it cool down for 10 minutes.
Open the trunk.
Remove the two plastic pins holding the plastic trunk cover using the flathead screwdriver.
Using the 10 mm socket and socket wrench, remove the two bolts holding the lens.
Gently pry open the lens using the flathead screwdriver.
Using your hands, pull away the lens slowly.
Take out the brake bulb by pushing it down and turning it counter-clockwise at the same time.
Put the new brake light in and secure it by pushing it down and turning it clockwise.
Test the new light by turning the car on before moving to the next step.
Еще один человек закончил это руководство.
